Well, it’s happening again.
Adieu
SoCal
Here is prime example.
A couple of years ago I bought a 2012 Ford Expedition EL Limited 4X4 with 65k miles on it, body and everything in mint condition, loaded with every option available, all leather, 3 tv screens, heated/cooled seats all the way around, front and rear captain chairs, auto leveling suspension, you name it, it has it.
I knew it needed some maintenance, engine checked out perfect, no oil leaks, compression issues, nothing like that, and being mechanically inclined I bought it for $12k
I wanted it for a secondary vehicle, family hauler, boat / RV towing, etc.
I wanted to put it back on top shape and be as reliable as I could.
I did all the work myself minus the tranny because I don't have facility to lift it and price was reasonable
To put it back on top shape, I did the following;
New battery
New Tires
New Plugs, fuel and air filter
Re-man tranny and transfer case
New 4X4 actuators (due to vacuum leak)
New half axle seals on the front
New brakes & rotors (heavy duty for towing)
Replaced manifold gasket and studs (known issue)
New bearing hub assembly
New Shocks / Springs front
Total invested when done, including cost of vehicle) about $22k
That same vehicle new, when I called around, with all options is running $76k to $84k
Even in the event I have to drop a new engine in it at some point, that would put me around $30k
Still less than half of a new vehicle in like new condition.
When I first seen the vehicle I could see it written all over it, a guy brings it in for brakes or something else minor, the salesmen walks up something along the lines of "Well, the brakes will cost $2,200 (which is crazy, heavy duty towing brakes and rotors DIY was around $375) then he explains the 4X4 actuators need replacing around $1,500 ($250 DIY), your manifold is starting to leak, another $2,000 ( $200 DIY), front shocks and springs $2,500 ($200 DIY), and the crazy list goes.
The customer is now looking at well over $8k just for some basic maintenance done at a shop, not including tires $1,200, tranny and transfer case, axle seals, etc at who knows how much a shop would cost.
The salesmen them turns around "You know, just for the cost of brakes and tires, I can put you in a brand new one under warranty for the same monthly notes.
The buyer doesn't care that it will be a 20 year loan, ending up paying close to $100k for a vehicle, all he cares about is the monthly payment.
And here I am, with a like new vehicle, paid off in 4 years.
I see the same thing, probably even worse when it comes to boats and RV's
It's beyond crazy
Relentless
Waste of money OR a trashed, bad-deal vehicle
Trainmaster
Old School Member
Rockaway Beach, NY
Something's wrong with this story. I get the point, and agree with the principle, but the numbers don't add up here.
Why would a two year old 65K mile truck be such a rat? Was it under water or something? Mine's got 100K and all it has needed is brakes.
Matticus
Salt Lake City
Putting $10K+ in a $12K 'back up' SUV, does not make sense. Why change a good transmission and transfer case? There has been others on this forum, that have amazingly done this. The 6R80 can go, at least 150k. Maybe 200k+. DIY is OK, but what is 'your' time worth? What if your AC goes or catalytic converters? Big dollar items. Hows is the driver seat and carpets? You get rear ended and totaled, all your going to get is book value. Realistically, the 2012 Expeditions sold for around $45K with rebates. 2012's do not have 4x4 actuators. It is Auto4wd and electronically controlled.
That's odd...I replaced the 4x4 actuators in my 2012 also.
https://www.rockauto.com/en/moreinfo.php?pk=3763701&cc=3015249&jsn=471
Adieu
SoCal
Mine got 136k and 189k and really don't need jack ****... well, ok, maybe a $20 blend door for occasionally clicking rear air on the '09
TXFishin
US
The transmission started having issues after about 10k miles towing 7,800
I didn't replace parts just for the fun of it I can assure you
And the point is, over a 2 year period, even with the work that was done, it has come out even still a 1/3rd the cost of a new like vehicle
Buying a new Ford at $70k to $80k and $750+ a month is what's stupid
Relentless
TXFishin
US
We're you doing any towing? My buddy replaced his at 80k and was not used for towing or anything
Relentless
TXFishin
US
Where did you get 2 years old from?
2012 Vehicle is 2 years old?
I bought it used two years ago, so that would make it 5 years old at the time of purchase
Relentless
Adieu
SoCal
Relentless
Whatevs, it's still-in-diapers mileage.
I've never owned ANYTHING with less than 6 digits on the clock, and never had anywhere near that laundry list of items to fix or similar repair costs
TXFishin
US
I would agree on that, and hope there is nothing else going on, this all happened over a two year period.
Prior to purchasing, I read all over where people are getting 200 k+ on Expeditions
Having previously owned Toyota's, one with 275 and another with just over 340k miles and no issues, spending $10k was definitely not on the list.
The items were not replaced all at once and then was too far into it to bail out.
Overall though, even with the work done, considerably cheaper than a new vehicle or taking a chance on another used, so hoping this will be good to go for a VERY long time
Had the need to carry 5+ not been in the equation I would have went with a Dodge and a 5.9
Relentless
TXFishin
US
wow changing out a 6R80 with 65k is pretty nuts. They are a bandless trans and when maintained they go 300,000+ miles with no rebuild.
They aren’t picky like the 4R.
I read the same prior to purchase, even reading where guys are towing 8 to 9k on a regular bases, but who knows what the previous owner did to the vehicle?
The new transfer case was purchased with the transmission, 5 year warranty, and they had a different opinion, same as yours, so hopefully was a dud or previously abused.
I have a 96 F150 with 236k miles, all original and still going that I was using for my tow vehicle prior to this
What was odd is when I called around on the transmission for the Expedition, 4 different mechanics called them "throw-away" transmissions, and mentioned that's why you don't even check the fluid, or can't really check it without a lift, they all said drive it till quits, and I've never heard anyone say anything like that before
Relentless
1955moose
Sounds like you need one mechanic that knows what the hell he's talking about. Letting these Transmissions go over 100k with the same fluid is what kills them. True it's harder to change all the long life fluid, but it's worth it. Especially if your stressing the trans with towing. It always kills me how many multi car mechanics, pretend to be experts on all cars. When I worked as a mobile mechanic years back, I was always learning. Every car/truck has some different way of doing the same repair. It would be like me doing a timing chain on say a small block Mustang 5.0, vs doing one on our expeditions. Same goes for transmission service. My 4r100 in my Suv, has 2 drain plugs, one for pan, one little one for torque converter. The newer 6 speeds have neither. But, fluid can still be drained, all 12 quarts or so. Just takes a bit more ingenuity. And a big ass cement mixing pan, so you don't make a mess.
