What size spacer
Skyjack
GA
I have a 05 2wd that I am wanting to just level out. I don't want the front any higher than the back. I want to put 285/70s on it. What size spacer would I need 1.75? Also what would be the best shocks to put on there to replace the factory? I want something a longer to help the ride out if the spacers affect the ride any. Thanks.
2004XLT
CT
I bought spacers advertised as 3" lift, however they measured 1.125" and provided 2" of lift..best to ask manufacturer for dimension of actual part. In my case 2" leveled mine out perfectly but it is 4wd which probably sits higher stock..See if you can find a spacer that measures about 0.75" to 1" thick to get the amount of lift you're looking for.
Once you get an alignment you won't have a decrease in ride quality. I found that mine rode better after the level, the body feels more disconnected from the suspension and road.
