for the console (assuming you dont have a sunroof) just pull down firmly, disconnect all the wires i think its like 5 plugs then there is 2 torx screws holding the 2 "map lights" in place unscrew them and replace bulbs (very simple) then pop it back together and your done, as far as the middle row i just pulled and wiggled them out (the entire housing) there just attached to the headliner with a metal bracket thats mounted to the headliner, unplug and replace (you might need a flat head there are spring clips that hold the bulb in place) then the 3rd row is the easiest just pop off the cover and it uses the same spring clips as the 2nd row and replace cover. now if you did the fold down visor mirror lights i cant help you there havent done those yet...hit me up if you want pics
