Go Back   Ford Expedition Forum > Ford Expedition Forum > Suspension
Register to remove these ads.
Suspension
6 inch suspension lift ???
This is a discussion on 6 inch suspension lift ??? within the Suspension forums, part of the Ford Expedition Forum category!
Ok so I have a 98 with air ride. I want a 6 inch lift kit but what I want ...
Reply
Old 10-22-2011, 09:04 AM   #1 (permalink)
Registered User
Default 6 inch suspension lift ???
Ok so I have a 98 with air ride. I want a 6 inch lift kit but what I want to know is since I have air ride, will any 6 inch lift work or do I have to find an air ride to coil over conversion kit? Also at what point does drive shaft issues start occurring? And lastly some sweet pics of expys with alot of lift would be nice!
__________________
I like ford but I LOVE DIESELS!!!
ShotgunSamurai8 is offline   Reply With Quote
Old 10-22-2011, 10:15 AM   #2 (permalink)
Thermo's Avatar
technical advisor
Default
Shotgun, due to the air ride, your suspension lift options are really limited. I might be wrong here, but there are no kits currently in production for air ride Expys. So, you have to either go custom or toss the air ride setup.
As for a 6" kit, there wasn't ever a true 6" kit made. Fabtech had what they called a 6" lift kit, but it was truely a 5/4" kit. If you can, you can also get a Rocky Mountain kit, but that was a 10" kit. BUt, I have heard some good and bad things about that kit.
I guess I have to ask the question of what you are trying to get out of the truck that requires that much lift? I am running 37's with a 4" lift (97 Expy, non-air ride). Now, I am pushing the limits of what the truck can handle, but that gives you an idea of what can be done.
__________________
Official Member of the Lifted Expy Club
Thermo is offline   Reply With Quote
Old 10-22-2011, 10:08 PM   #3 (permalink)
SOLISIMO's Avatar
Default
Welcome!
__________________
SOLISIMO is offline   Reply With Quote
Old 10-23-2011, 01:16 AM   #4 (permalink)
Registered User
Default
Well I know I'll have to ditch the airbags for the lift, but I just want a big truck! I love my expy and I already have 35's on it with a 3 inch body lift. But now I want to go BIGGER!!! lol Ive seen a couple like this and I love the way they look, now I want one
__________________
Old 10-23-2011, 02:11 AM   #5 (permalink)
thebeast1190's Avatar
Default
I also have the four wheel air and am having a suspension lift installed. Its a custom job. Try to locate a four wheel drive shop near you, they should be able to help. I contacted fabtech and they recommended a place. Its costing me about $4500 for the kit and install.
__________________
99 EB
thebeast1190 is offline   Reply With Quote
Old 10-23-2011, 08:45 AM   #6 (permalink)
Thermo's Avatar
technical advisor
Default
Shotgun, your best bet would be to see if you can find a Fabtech 6" lift for the front end of your truck (can get a kit for an F-150) and then see if you can find the rear kit from Rancho (kit it out of production, so, that may be a harder find). If you are lucky, you can find a Fabtech kit for the Expy, but that is probably an even harder find. Your limiting thing will be getting the longer arms for the rear axle (4 of them, 2 on each side) and then getting a drop bracket for the 5th member. Getting the taller rear springs should be able to be done by any 4x4 shop. That is pretty much all there is to the rear lift kit other than longer sway bar ends. But this is a cheap modification if you have a welder or can be taken to a weld shop and they can extend them for you. Just tell them that you want the bars extended by how much lift you are adding in the rear.
As for tire size, if you are going with a true 6" suspension lift and already have the 3" body lift, you can squeeze in 38x13.5's on 9" wide rims. You may still end up modifying the rear of the front wheel wells to give you a little more clearance there and will probably result in a good trimming of the plastic valance too. But, worst case, you may end up having to cut the front bumper a little bit (1" at the bottom corner, tapering to nothing at the top). I had to cut the bumper to make my 37's fit.
__________________
Old 10-23-2011, 03:11 PM   #7 (permalink)
Registered User
Default
Wow thanks guys! You know wen I bought the expy I thought the air ride was the coolest thing ever! Hooked up a 4 place covered snowmobile trailer up to it filled with atvs and it squatted quite a bit, turned on the key and it leveled right out, didn't squat an inch. Now that I want a lift it seems to be causing quite a headache. Well since there are no 6 inch suspension is there maybe a good 4 inch out there that someone could recommend?
__________________
Old 10-23-2011, 06:46 PM   #8 (permalink)
jacks3am's Avatar
Default
all you have to do is get a six inch lift and lower the front shock mount down four inches and get standard suspension torsion bars, and be done!
__________________
97' EB 5.4, Michelin LTX A/T2'S, k&n drop in, pioneer headunit, rancho rs5000's and painted fenders
jacks3am is offline   Reply With Quote
Old 10-24-2011, 04:03 AM   #9 (permalink)
Default
Ive been doing quit a bit of research into lifting a air ride expedition What Ive came up with is that the front, top top shock mount will need to be dropped 4",
and there is a traction bar that needs to be extended 8". (heard this from one source anyways)
also the air ride expeditions have weak torsion bars, so you will need a set from the standard susp exp/f150
You will also need a coil spring isolator
I talked to my buddy who works at a ford dealer, and he says that the air ride suspension is pretty similar to the standard suspension, (same control arms, ball joints, tir rod ends etc) and he said it shouldn't be that hard to put a lift on it
I plan on tackling it this spring, and im going to do a very thorough write up, with many pictures, and then no one will ever have to ask this question again
Also Lookie here:
http://expeditionforum.com/showthread.php?t=5922
that guy did it, he dont anwser pm's though, i tried asking him about it
I managed to lift my old Golf cart with some scrap metal, so i figure i can probably figure this out
Heres a pic of what im pretty sure that guy said he had to extend:
http://i290.photobucket.com/albums/l...Expsstuff2.jpg
masterhacker is offline   Reply With Quote
Old 10-24-2011, 04:16 PM   #10 (permalink)
walnuts4x4's Avatar
Default
was gonna say look for that link you posted was one of the only lifted 4 wheel air expies I have seen but hope you get a 6" kit they are cool....lol
__________________
2012 Jeep Patriot....
Formerly a 99 expy with 11" lift and 37s...
walnuts4x4 is offline   Reply With Quote
Reply
Bookmarks
Tags
suspension lift
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Dodge Ram Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
Scion FR-S Forum
Softball Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
