Overhead compas/temp gauge problem
mille1cw
Centreville, Virginia
Hi, my overhead gauge is reading considerably lower temperatures then what it actually it outside. Does this depict a faulty thermometer? if so where is it located and is it an easy fix? Also the compass is spot on, any help would be great!! Thank you
1997SCEBFEX
Northwest Panhandle
Mille1cw:
I can't tell you where the sensor is, but what are you using as a comparison for temps-two separate sources?
Depending on where the sensor actually is, i.e. sun, shade, etc., there could be variations.
I installed an aftermarket one temp gauge and the probe is behind the passenger side front bumper and it is very sensitive to road heat and if sitting in traffic for a while.
sure others will chime in & let us know what you find.
mille1cw
mille1cw
Well my truck is reading at least 15-20degrees below what it normally should be. I am using my smartphone/ weather.com for my reference point every morning. I'll do some more searching to see what i can find. I'll check the passenger side bumper as well
1997SCEBFEX
Northwest Panhandle
Yeah, that's certainly high out of specification. Again, I have NO idea where the OEM sensor/probe as mine was not outfitted with that. Sure others could quickly tell/direct you to it.
atle
Fairfax, VA
not sure if you found the answer yet, but, driver side, right inside the front grill near the headlight
hammerg26
North Georgia
Any chance it is reading Celsius????
Jefes_Shyt
