Looking for aftermarket headlights.
Clayc84
Nottingham Pa
I simply replaced mine with a set off ebay. They are the clear housings don't have the textured inside like the stock ones. Used stock bulbs for now and made a big difference.
I
IMINYOURCHAIR
Altoona Alabama
Do you have a link to the housings? Can you get me a pic of the beam output?
Clayc84
Nottingham Pa
I didn't use the corners either so you should be good. I plan on putting HIDs in at some point to get even better lighting
I
IMINYOURCHAIR
Altoona Alabama
Update: I finally got a pair, ordered these, got them in and aligned today before the snow hit again. they look great on the truck but the beam wasn't what I expected but still usable. I plan to put hid projectors in the housing in a few mos anyway so it'll do.
I will post pics of the beam pattern since I couldn't find any before purchase..
ks10308
New York City
2000 Ford Expedition Headlight and Corner Light Kit at 1AAuto.com
I bought my headlights here and they look like the lightning ones and light the road much better. Plus they have a 5 year warranty. If you are going HID, make sure you buy a good quality german set, not cheap chinese. Had an experience with cheap chinese. Make sure it's 4300K. And if you do put HIDs, make sure you DO NOT use stock housing. The stock housing are lense style housings designed ONLY for halogen bulbs. The beam will be useless and it will blind other drivers. The reflector housing (clear with the metal bracket in the middle of the housing) and projectors are good for HIDs. make sure you only use 35w for the reflector style bc it doesnt have a cut off line like the projectors. 35w on reflectors are fine because they do not blind other drivers.
Dmcritt22
