Ok to use this terminal for " 12V Ignition " source?
AZ59apacheguy
Fountain Hills AZ
So I am ramping up for my electric fan install and have question about hooking into "12V ignition ". The picture below shows where relay 302 resides in the fuse block. Per owners Guide, this relay controls " Trailer Tow Battery Charge Relay ". I am not using this function and there was no relay there to begin with. I would like to use the one terminal on that relay socket for " 12V Ignition " source for my fan controller. I have verified ( looking at the picture ) that the top terminal is an " ignition source ". I do not want to have to rip into my dash and splice wires to accomplish this. Does any one see an issue with me using this terminal for ignition source? Thanks
stamp11127
Temple, Georgia
What is the controllers current draw in amps? You size the wiring and fuse to the current draw(load) plus a few amps for margin.
A
AZ59apacheguy
Fountain Hills AZ
Hi. There is two inputs into the controller. Terminal #1 goes straight to the battery terminal, this wire ( 20 AWG ) requires a 2A fuse inline. Terminal #2 is the " Ignition " feed , I believe it's just used to tell the controller to " wake up ", there is no fuse requirements on this wire ( 20 AWG ); should I fuse it just to be safe? The controller is capable of supplying currant draw from the fans up to 125A, my fans will only require less than 50A max. Your thoughts
stamp11127
Temple, Georgia
Adding a fuse would only be necessary if the fuse protecting the circuit you are branching off of is rated higher than what the controller draws on that ignition wire.
Example: If the source circuit is protected by a 30amp fuse but your new branch circuit will only draw 5amps, then you are not protected. In this case you need to fuse it. You are fusing a 5 amp circuit with a 30amp fuse.
The flip side of this with the same scenario is the main circuit draws 25amps, the factory fused the circuit with a 30amp fuse. You now add a branch circuit that draws 7.5amps. Total draw on the circuit is now 32.5amps. You will start blowing fuses when both circuits are on. Plus you have eliminated the built in buffer from a slight overload of the main circuit.
Connect per their install instructions then read the current draw on that circuit and fuse appropriately.
A
AZ59apacheguy
Fountain Hills AZ
So what do you think about me using the terminal on that solenoid receptacle for " ignition sourced " 12V? In the first pic, it's the one at the top ( 12:00 ), in place where the Trailer Tow Battery Charge Relay is supposed to reside
stamp11127
Temple, Georgia
Could you tap a branch circuit there - yes. But that isn't the best way to do it. If the battery junction box has a positive lug on one end you could tie the circuit in there and run the wire with the existing harness, just zip tie it in place.
For terminals, use only the higher quality "crimp - solder - heat shrink" type. These are almost indestructible if attached correctly but cost more than the junk terminals most auto parts stores carry.
A
AZ59apacheguy
Fountain Hills AZ
Hi, thanks for the reply. Could you explain why that's not the best method of doing it this way. Also, hooking the " ignition feed wire " to the positive lug wouldn't be considered iginition power.
stamp11127
Temple, Georgia
From a professional standpoint there is nothing to secure the wire to inside the box other than where it plugs in and then at the harness. Neatness counts.
Do you have the wiring diagrams for the power distribution?
I'll give more info later, been driving all day picking up another project car - I'm not 18 any more.....this Ga heat & humidity is zapping the snot out of me today.
waleedalmadani
