KWT2000
motorcraft is not my first choice because of the price for ford to put there name on the product most original equipment o2 sensors are Bosch... as for the exhaust leak if the leak is between sensor 1 and sensor 2 that could cause the same condition and the same code. Bank 1 is the passenger side on the tritons the easy way to tell on any V engine is locate both front spark plugs one on each side which ever one sits farthest to the front that will be bank 1...sensor 1 is the one between the exhaust manifold and the cat. converter, sensor 2 is down stream. hope this helps you out
