Check engine light
KWT2000
NINE MILE FALLS
motorcraft is not my first choice because of the price for ford to put there name on the product most original equipment o2 sensors are Bosch... as for the exhaust leak if the leak is between sensor 1 and sensor 2 that could cause the same condition and the same code. Bank 1 is the passenger side on the tritons the easy way to tell on any V engine is locate both front spark plugs one on each side which ever one sits farthest to the front that will be bank 1...sensor 1 is the one between the exhaust manifold and the cat. converter, sensor 2 is down stream. hope this helps you out
M
mic_1011
yonkers n.y.
thanks man, i'll try to save some cash and go with what i've got. if that doesn't help i''l go bosch and if that don't work i'll get back to you either way. i don't think the leak is between them, i think it's closer to the headers
acepete
CA
I have a similar issue but mine is bank 1 sensor 1. I have already tried a new sensor and light still comes on after computer has been reset. Not sure what else to do. If any one has any ideas let me know. Thanks,
