New here, just signed up.
Steve101
dominican republic
Hi all, will post a snap of my motor soon, in the meantime I have this following problem.
Model is XLT (late 2011 5.4L petrol) only 30,000 plus miles on the clock.
When I start the motor first thing in the morning it sounds like a tank (diesel engine) starting up then after about 2 seconds it sounds normal. Drives ok for about 30 miles then I will feel the car missing every now and then. Any ideas, I know its a long shot, hope to get to garage soon to have checked out.
Appreciate any info that might help me out.
Regards
Steve 101
stamp11127
Temple, Georgia
CEL is the check engine light
When the engine computer (pcm) detects something isn't right it will put a code into memory and turn the cel on. Mechanic will connect a code reader or scanner and retrieve the code(s).
stamp11127
Temple, Georgia
That is a "famous song from the workplace".
I is in
T is the
W is wind
Use your imagination for P
autoarcheologist
US
Missing is typically a spark plugs or coil issue.
Noise on startup seems to be common until the timing chain tensioner fills with oil pressure again.
Sent from my ONEPLUS A3000 using Tapatalk
1ATony
Supporting Vendor
Supporting Vendor
mass
Thanks for joining Steve, It's great to have you here
Tony
