98eb5.4
Hey Guys....and gals. My '03 Expy has open differentials
how'd you find that out? what gear ratio?
https://www.carid.com/ford-performa...204-f318c.html?singleid=56773784&url=84934582
Brand new ford ones. (LSD).
Personally, I would install an E-Locker.
that's for 8.8
Thanks, JE07. But when I look at that I think it's for the front differential...
The rear is a 9.75 34 spline. But I'm sure I can get a new replacement LSD since they did offer them for my model year.
Probably quickest and "easiest" way to do it is just go to a salvage yard and find an Expy or Navigator with a "H6" code on the door jamb sticker ( 3.73 Limited Slip ), and pull and swap with that complete axle. Unless you're going rock crawling that should be good enough. The limited slip axles were actually more common than non-limited slip .
