Front shock lower bolt size
Tedstech
Does anyone know the size of the lower front shock bolt to a 2006 navigator. Thanks in advance.
MWguns
Kansas City
I know on my 2004 a 30mm deepwell fits, but has just a very small amount of play around it. Its not enough for it to be an issue or to strip though. I had a 30mm deep well impact socket on there and torqued it to spec just fine.
Edit: had to fix a few mistakes so it did not look like i had a stroke half way thru. Gotta love talk to text. Lol
Jeff55v
Illinois
My Expy is older than yours, and it had been molested a lot. Many of the suspension bolts (including shock bolts) had been replaced with the wrong diameter bolts. Someone removed the metric size bolts and installed SAE bolts. This caused a lot of suspension noise.
I can’t remember exactly the diameter of the lower shock bolts, but I know they are definitely metric.
0608expy
Piedmont, OK
Did front quick strut replacements last week on my 06 and it is a 30 mm deep. And you need a 21 mm deep for the tie rod end.
Adieu
SoCal
Everything on stock Fords is metric.
That said, some American aftermarket parts like top strut mounts may be SAE if they've been replaced
PS ~however~, with big-ass bolts like 30mm the metric/SAE distinction becomes moot... if you can't find a 30mm deep impact socket, 1 - 3/16" deep impact will do JUST FINE.
Also, not sure if this is the case for you, but afair on my 3rd gen the other side of the nut/bolt pair that needed the 30mm was a 27mm... this too is also approximated just fine with a 1 - 1/16" SAE socket.
If you're having trouble finding them, SEARS is one of the few brick and mortar shops that still stocks a variety of socket singles past 20 mm and 1".... They had something that worked out every time when I needed 27mm, 30mm deep, 32mm, and 36mm.
However, even their selection is dwindling, so if you're not willing to spring for a large expensive socket set, you'll often have to go to a SAE approximation of metric or get something not as deep as you wouldve liked and/or non-impact....
r98exp1
