2007 EL needs air to coil suspension
JDMitchell
Fort Leonard Wood
I have a 2007 EL and have a blown air shock on the drivers rear. The passenger rear is also leaking slowly and I want to do a conversion to coils. I have found several very inexpensive conversions from Monroe, Suncore, and Unity. The only one specifically listed for the EL that I have found is from Strutmasters and if I can get away with half the price I will. Anyone put the regular Expedition conversion on an EL? It is only about 200-300 pounds different and I only tow a tiny trailer for my kayak so heavy stuff isn’t needed for me. Any help?
Adieu
SoCal
95% sure Rancho and Bilstein and Monroe warnings saying "will not fit air ride" are solely referring to the fact that it won't be air ride ANYMORE once you install em
Note that bilstein is JUST the shocks.... you'll still need the coils and the mounting hardware and you'd need to buy that elsewhere
Except for the module for fooling the air ride electronics, the strutmasters kit has el cheapo chinese versions of the same shit offered in better Monroe and Rancho quickstrut coilover kits
JDMitchell
JDMitchell
Fort Leonard Wood
Thanks for the info. I ordered the Suncore conversion and will hopefully have good results.
JDMitchell
JDMitchell
Fort Leonard Wood
The Suncore kit worked great. It only took about 3 hours including a couple beers. For $180 I think it is the best bang for the buck. My EL sits right at 1-1/4 inches higher then it did with the factory air struts. It might settle a bit but the ride quality was affected very little so I’m just happy to not have to worry about a saggy ass.
johnjohn205
