theoldwizard1
2018MYMaybe there is a "model year" when the problem ceased to exist?
Does anyone know this?
You're spot on. I just came back from the local body shop (VERY highly rated, certified by all the manufacturers to do repairs, and they have a separate building specifically for aluminum work so nothing gets contaminated) and before we even got to my truck the estimator said "If you're here for the hood and liftgate, they cannot be fixed."That is actually kind of cool, but the problem is unless you clearcoat it, that aluminum is going to oxidize badly. And a relatively short amount of time too. If you clearcoat it the steel that is compromising the aluminum panels in the problem trucks is still there and going to cause galvanic corrosion which will cause the clearcoat to peel and you’re in the same position as before. At least that is my theory. Might be complete hogwash.
2018MY
But paint bubbling on aluminum panels is covered since 2016MY.Incorrect, the TSB extends from 2000-2018 F-150 and Expedition vehicles.
That does not seem logical to me ! If you remove all paint, primer, trim and other hardware and then properly prepare the bare aluminum surface it should last a lot longer than 1 year !He went through the whole galvanic corrosion thing, explaining that the panels are contaminated from the factory and that Ford refuses to do anything about it, etc. He said after full stripping and prep, best case scenario is a year before it starts bubbling again.
Thanks for correcting me on “verbiage”. Alloys not grades. Sorry. As for the corrosion thing you’re incorrect, it’s not fixable. The panels have steel contamination in them. You can’t remove it. It’s somehow impregnated into the aluminum. But if you want to waste your money, go for it. But some chemical engineers have already researched this and indeed it’s not easily fixable. In fact I wish someone just made steel replacement hoods and liftgates because that would be the solution. Or clean aluminum replacements. But that won’t happen.
