Thoughts on this combination?
Dark Z
AB Canada
Hey gents, I have been thinking about adding another set of wheels lately. Below is what I'm currently considering, not sure if this setup would fit? I recently installed the gatorback mud flaps, the original 22" is rubbing a little on certain angle, I have a feeling this setup might also rub? Thanks!
Tires: 275/55R/20 Goodyear Wrangler Duratrac
Wheels: Black Rhino Zulu 20x9.5 30mm Offset
dlcorbett
tx
Does the set have to two tone color sscheme as well?
byz250f
SE MI
If you want to sell your 22s let me know. Im looking for a set.
1955moose
What year is the Expedition? 2 or 4 wheel drive. Your 275/55/20 tire size is an option on the new 2018/19 F150, so it should fit. But that said you've got to compare rim offset, between yours and the new Ford ones. My 2000 4x4 has 285/50 r20. But mine has what I believe is a 1 1/2 inch lift, and street tires. I don't know what offset I have, as I've never measured it.
Dark Z
Dark Z
AB Canada
2018 Max Limited, I think I have a found a setup similar to my planned setup with 30mm offset wheels. The new wheel setup should be little smaller than the stock 22" setup, which is good since I'm getting a bit of rub on the new mudflaps.
1955moose
Should work, might want to bolt up a bare rim front and rear and check before mounting tires. Lot of work to break down 4 tires if your not clearing.
Jefes_Shyt
