TPMS display on phone via BT OBD adapter
ChiefsFanInMD
MD
Hello. I have spent over an hour looking for a post I saw, so my apologies in advance.
I had seen a post, (believe it was from @LokiWolf), where the tire pressures were shown on a cell phone, by using a BT OBDII adapter and forscan
I have a 2017 Expy and doing it on the dash isn't possible, so this workaround is a great solution.
Does anyone have info on which combo of OBDII / software could make this a reality?
thanks
Super Moderator
Super Moderator
thanks
Was just about to reply to your message, but figure answering here makes more sense, so others can see it.
You need a MSCAN capable OBDII BT adapter. I HIGHLY recommend a OBDLink MX+. It is one of the more expensive($99) out there, but is BT LE, and can work with iPhone, Android and Windows. If you have patience, it goes on sale on Amazon for $20 off every now and then.
I use to use it on my 17 for monitoring stuff with the FORSCAN mobile app, or OBDLink App(OBD Fusion app rebranded for OBDlink). I also used it paired with my Windows Laptop, and still do to do any FORSCAN changes. I have had mine connected to over 50 different cars at this point. It is A REALLY good adapter, and recommended by FORSCAN.
I used to monitor Boost, Coolant and Trans Temps, and Tire Pressure live when traveling.
JasonH
Houston, TX
thanks
ELM327 adapter and Torque Pro. I think I posted a screencap of my setup previously, but I can't find it.
ChiefsFanInMD
ChiefsFanInMD
MD
thank you!
