I finally got the trans cooler installed. It took a couple of months to get all the parts. Everything seems the same but I haven't tried towing anything yet. I did not replace the radiator. The next step will be to add the 7-pin plug and the brake controller. I am going to stick with the Ford parts. Any other suggestions?
If you go with the Ford brake controller then you’ll need to enable it via Forscan (if I recall correctly from other posts). It fits right in the slot and looks nice.
I went with the Prodigy brake controller because of my past experience using it on other vehicles.
My recommendation is to go with the 4/7 pin connector so you never need to worry about having an adapter. Walmart stocks them.
It was very easy to run a new line back to the 7 pin to supply power to the trailer. See my previous posts which include pictures etc.
I didn’t look to see which year you have but if you have a 2015-2017 and get stuck then message me. I’m not on here very often but if you give me a heads up AND have an iPhone then I’d be willing to FaceTime with you and do a walkthrough around my Expy.
