Moonroof cover not closing all the way; adjustment possible?
pw1981
Tampa Bay FL
My moonroof cover used to close all the way. Now it leaves a slight gap at the front which, depending on time of day and cloud cover, makes a noticeable light area still visible.
I typically only open the cover in the early morning, evening, or nighttime and keep it closed when parked or during the day because it’s Florida.
Is it possible to adjust the cover so it will slide that last maybe 1/4 inch needed to block the light? It used to cover it, and at some point it stopped doing so. I’ve tried sliding it manually, but that didn’t work.
I attached a photo showing the small gap.
You may want to post the year of your Expedition, as there may be a repair for a specific year.
There was a TSB for 2018 Expedition models regarding the sunroof.
DWs-TTEB
Evans, GA
I'd try that re-program/learn thing these moon/sun roofs have. Let me see if I can find that video for you. I did it myself over a year ago & forgot the button pushing sequence.
Deep8174
Canada
To me, it looks like there is a curve on the headliner. If you push the headliner up slightly, will that gap disappear?
pw1981
pw1981
Tampa Bay FL
Mine is a 2018. I am not sure why my signature isn't showing up where I had that listed. Sorry about that.
pw1981
pw1981
Tampa Bay FL
No sag that I can see. Pushing the headliner doesn't seem to make any discernible difference.
8131full
Las Vegas
no, its not a sag or a curve or anything. You just have to recalibrate it. Mine does it all the time. Its kind of a process, but that vid above spells it out pretty clearly. I'd also recommend the specific lube for all the seals while you're at it. Amazon has it. Its expensive but makes everything work better.
Rob6805
Is this the stuff?
Krytox by Chemours GPL 205 Grease, Pure PFPE/PTFE, 0.5 oz Tube (D10170248) https://www.amazon.com/dp/B00MWLDALQ/ref=cm_sw_r_apan_i_2S0GB2QNFKQDEHFKZ1PD
