Traction Control ??
Deadman
Gosh I wish mine was less invasive. In any snow, the damn traction control cuts ALL the power and then the retarded trans thinks it should shift up 2 gears. Then the TC gives me back the throttle and now its 2-3 gears too high and takes a few seconds to shift back down into a reasonable gear, and THEN we can finally start moving forward again. Its ridiculous. I wish it wasn't there, and its too much BS to fiddle with to shut it all off every time I restart the car.....
2020-MAX-Limited
Colorado USA
Are you in a 4x4 mode? I've never experienced a wheel slip or TC activation when in 4x4.
Deadman
Sometimes yes, sometimes no. Its annoying when there is just a little batch of ice by an intersection and I'm in 2wd and it slips and kills all power. I keep 4A off when I don't expect to need it as it wears the front end out by spinning everything for no reason.
D
dtximages
Dallas, TX
OP here and update: We just had ice/snow in Texas and I was able to play around with the TC and 4A.
1. I think the TC is different in this car as it doesn't jump/jerk, it simply lowers power drastically but it's smooth feeling and causes me to believe it's not working.
2. 4A worked very good in the ice/snow
3. Michelin CrossClimate tires are awesome in this weather!
Calidad
So today’s vehicles get stability control systems tied to what drivers often call traction control. Each vehicle gets a level of tolerance for traction loss based on the design of the vehicle ie the vehicle stability envelope.
If your prior vehicle was older and / or had reduced stability you would definitely notice the “traction control” systems being more aggressive regarding chopping power to prevent an uncontrolled skid.
I have noticed that the Expedition nanny is far less aggressive than my Toyota Sequoia. Thats going to have many reasons including the inherent stability designed into the Expedition
Also super aggressive nannies that cut power at the slightest loss of traction can cause serious performance issues and definitely trigger angry owners
My Sequoia occasionally would totally cut power to zero on right hand turns in the right conditions ie up hill street it would bring you to a dead stop mid turn. Well known gripe with the Sequoia owners
Calidad
Tire’s definitely make s huge difference. The oem tires were terrible at 15,000 miles I couldn’t take the constant sliding anymore even wet pavement they were traction challenged. BFG trail Terrain new 3peak a/t tire for SUVs. Massive difference not even comparable 2whl with these tires can get thru snow that 4whl struggled with.
