cottong2001
Hey guys. 07 Expedition EL. I installed Monroe Quick struts about 1 1/2 yrs ago. Never liked the ride with the new struts to begin with but now I'm bouncing all over going down the road.
Here's the problem: instead of doing quick struts again, I thought I would just replace the shock. But the Bilstein shock does not fit the Monroe Quick strut lower spring seat. The Bilstein is significantly narrower in diameter. Only thing I can guess is Monroe designed their own spring seat to fit their shock.
Stupidly, I did not hang on to the OEM assemblies. I'm assuming the Bilsteins would fit that.
anybody else run into this? I'm not sure if I buy an OEM spring seat whether it will fit the coil. If Monroe changed the spring seat design, maybe their coil is different too? Aggravating.
Oh and I can't find an oem strut assembly at any junk yard.
