Junkyard Monkey
- Joined
- Sep 22, 2005
- Posts
- 12
- Reaction score
- 0
The vehicle in question is a 2000 Expedition 4x4 EB.
The rear diff was slipping a little quite some time ago. After replacing the fluids and using the additive, the slip went away almost completely.
I had the vehicle in the air recently due to a tire failure. In the air, I rotated the tire back and forth and noticed a bit of play. The slipping seemed to have crept back.
Then today, it really seemed to slip when going up hills. My wife described it like the engine was misfiring, but when I took it out, it seemed like the rear diff was slipping. When I put it in 4wd, the slip diminished dramatically.
With the help of a friend with a micrometer, I have done a rear diff ONCE before on a completely different vehicle. I am guessing that this is not generally recommended for a home mechanic. Is that true? I can do a lot of things, but I learned last time that measuring the spacing and play was fairly precise work. What kind of micrometer should I purchase if I did this? Wouldn't I still need a machine shop to deal with packing the bearings and stuff?
If you recommend having it serviced:
1. What should I expect to pay?
2. Is a general mechanic much diff than a dealer for this?
3. Is a tranny shop better than a general mech for this?
Thanks for any help!!
