04 Expedition Fuse Box needed
euromerc
UK
My truck died, so I followed the instructions on youtube, and its the relay in the fusebox.
On ebay the going rate seems to be about $65 to repair them.
Problem is I'm in the UK and all parts have to come from the US, meaning I can't get mine repaired.
So I need to buy either a new one or a good used one, anyone know of a source of either?
Bedrck47
Elizebethtown, PA
You would be better buying a new one If you get a used one you may wind up having the same problem
Bedrck47
Elizebethtown, PA
BTW welcome to the Forum.
If you order a new fuse box make sure you match the part numbers Its on a tag on the side of the fuse box
E
euromerc
UK
I put power to the green yellow wire in the passengers footwell, started straight up
Bedrck47
Elizebethtown, PA
Read the link I provided and look at the video also the thread will tell you how to by-pass the contacts
E
euromerc
UK
It would still be nice to have a new relay though, anywhere where I can buy a new one?
Bedrck47
Elizebethtown, PA
Check e-bay
My suggestion for the jumper is just a temporary fix
If your any good at doing solder work on a circuit board you can make the repair
E
euromerc
UK
Looks like I just need a $9 omron relay, and someone with soldering skills, happy days!
sharprd65
