collazoscesar
Truck got a tpms sensor failure after hitting a pot hole on left front driver side.
Some air leaked out from valve. I decided too changed the sensor And purchased a new motorcraft replacement sensor.
I installed it but when I'm starting the programming process lcd says program front left tire, I go too tire and use the programming magnet on stem nothing happens. I've changed them before in the rear with no issues. Do you think I got a bad sensor, the tire is inflated to proper psi. Am I able to skip that tire and continue too program the other tires. Could it be something wrong internally and not the new sensor.
Thanks in advance for your advice.
Sent from my SM-N910P using Tapatalk
