B
bedrck46
Guest
after you reset the switch and tried to restart did you by chance try using carb cleaner or either to see if it would fire up??
check fuse 50, 72. 32 and 71 in the battery junction box
take a volt meter and check to see if you have 12V into and out of the shut off switch
Have you checked the Fuel Pump Driver Module? This is a common problem on F150's and causes the same problems. I would assume the Expy is designed the same way. They bolt an aluminum module to the steel frame and it easily corrodes.
