I've been researching everywhere I can find.
Checked blend door, functions and seals.
Ran Diagnostics on automatic AC, checks good.
Pressures at 5-10 min idle with front on max ac and rear on 3.
Low = 48
High = 250 ish
When I turn the rear off, the pressure on the low side drops below 40 and the air out of the front gets warmer. When I have the rear on high, the pressure builds back up to 50/250 and the rear is kinda cold and the front is cooler than outside air but not by much (the rear is slightly cooler than the front).
I cut a hole in the plenum to test the blend door and noticed the air from here fluctuates cold and warm. The warm does not come from the blend door, it just fluctuates. The Evap is kinda warm to the touch but the pipes on the bottom are cool and has condensation.
Why does running the rear AC make the air all around a bit cooler? And what could be keeping everything form being cold as should be?
Low = 48
High = 250 ish
