hertfordnc
Had this truck for 50K miles, (out of 170,000)
Last year I replaced the intake due to water at cyl #4
Never ran quite right after that.
First problem, there is no power to OBD port (and cig lighter) can't find fuse. online is no help. I checked every fuse, can't find it. Yes, the owners manual is long gone. If someone has a fuse diagram that would be awesome.
Can I hot wire the OBD port? It looks like pin 15 is the main power wire.
Obviously diagnosing the problems will be a lot easier once I get some codes but lets go over what we have;
When I changed the intake I replaced plugs, coils and injectors with mostly cheap stuff. When I was done I still had a misfire code around cyl 5 & 6. It came and went and I needed the garage back so I just started driving it. The truck ran pretty good, the CEL stayed on.
Couple months ago it began stalling, idling poorly, hesitating on launch and really running like crap
In the absence of OBD info, is there anything I can look at related to those symptoms?
And when I get OBD info what codes should I be expecting?
WHats the failure rate of low end injectors and coils? I spent less that $200 on all of it.
thanks
thanks
