Bedrck47
For one expy girl tried to repair the fuse box and failed Can't say why as I have no idea how it was done or if she used an old relay. Then she listened to someone that told her a fuse box for an 04 nav would work and it did to some degree. After having been thru this problem many times with other members I sent her some information and even a comment from a truthful seller on e-bay that knows the part numbers have to be the same and Also from my experience that the 03 uses two different fuse boxes I have not heard back from her since Typical of many new members.
Now you need to decide if you want to take my advice or continue to search the forum or google for someone else's advice. The PCM doesn't not vary the voltage to the fuel pump.
Get yourself a new fuse box or one from a salvage yard and hope its in working condition or replace the relay on the board
If you have tried the jumper and the expy is running you now know the relay is faulty.
Sorry for being blunt
