2003 EXP. Crank no start!
Bugatti32
Are there any indicators that the fuse junction box/ power distribution panel behind the passenger side kick panel is shorting out or going bad before it actually stops functioning?
Bedrck47
Elizebethtown, PA
You may hear the relay buzzing or smell burning or frequently having the engine shut off or stall and take longer to restart.
of course any of the above could also be symptoms of other problems
or you can look at the fuse box and see if you see any signs of burning around the relays
are you having any problems at present
B
Bugatti32
Yes I experienced the stalls after replacing the battery, but heard the fuel filter croak and replaced it. So for two weeks ran beautifully, MPGs went back to exceptional and the horsepower was back to normal with over 250,000 on the Triton beast.
B
Bugatti32
I have run through the fuse junction box fuses, and swapped relays around. As well as a couple of simple problem indicators. What do you have in mind?
Bedrck47
Elizebethtown, PA
I have a few things in mind BUT
I need you to answer what I asked
Is it running now or still wont start?
Jefes_Shyt
