Riphuero
Hello hopefully someone can help. Thanks
googled it
So now I'm confused I know where the CHT is but need to know where the ECT is on my vehicle? Is the CHT the same as ECT? I can't seem to find a diagram of its location. ThanksRight, but that's a different year which uses a different version of the 5.4. There aren't many similarities between the 3V and 2V engines, and the sensor is a completely different location.
The OP is looking for the Cylinder Head Temperature Sensor in the following diagram:
Is this also for the 2004 EB 5.4? I need to go underneath and check. Thanksgoogled it
Isn't this the Cylinder head temperature sensor?Your 2004 is a 2V motor. It's different.
This video is a 2V motor coolant temperature sensor change out ....
There is no coolant temperature sensor, just a cylinder head temperature sensor. The PCM infers coolant temperature from what it sees from the cylinder head temp sensor.
The advantage to this is an accurate reading if air gets in the system. A classic coolant temperature sensor will read a lower temperature when surrounded by air even if the engine is scalding hot, which is cause a lot of overheats over the years. The cylinder head temperature sensor reads metal, not liquid, so will accurately report an overheat if you're truck pukes its coolant all over the ground.
Thank you. I just don’t understand how they sell a ECT for my vehicle when it doesn’t even have one. Thanks again
