awojtowicz
i have a 2005 thats giving me a low oil pressure warning. it starts knocking bad and the check gauge light comes on plus the oil gauge drops. i can turn it off and then its back running fine. i just took it for a test drive and it ran perfect until maybe 30 minutes into the ride. i had the p0345 error code about camshaft position sensors. i changed both of them and still having the problem. this all started after an oil change before covid hit. so truck was sitting for a bit. in reading the error i saw posts about wrong oil, wiring problem, camshaft position sensors. i even added a new ground from engine to frame since its really rusted underneath. not sure whats going on? checked oil pressure and it was fine.
