2005 expedition low oil pressure warning
awojtowicz
Old Bridge, NJ
i have a 2005 thats giving me a low oil pressure warning. it starts knocking bad and the check gauge light comes on plus the oil gauge drops. i can turn it off and then its back running fine. i just took it for a test drive and it ran perfect until maybe 30 minutes into the ride. i had the p0345 error code about camshaft position sensors. i changed both of them and still having the problem. this all started after an oil change before covid hit. so truck was sitting for a bit. in reading the error i saw posts about wrong oil, wiring problem, camshaft position sensors. i even added a new ground from engine to frame since its really rusted underneath. not sure whats going on? checked oil pressure and it was fine.
99WhiteC5Coupe
You have a disruption in your oil pressure supply.
What type of oil filter was used for the oil change you mentioned? Has the oil & filter (high quality such as Motorcraft) been changed since?
Yupster Dog
Super Moderator
Super Moderator
Get your battery checked at autozone to make sure its good.
Check the rest of the battery cables with a voltage drop test to make sure your getting good power and good ground. Always important to have that before trying to troubleshoot anything else.
A
awojtowicz
Old Bridge, NJ
i used a motorcraft oil filter. not sure what brand of oil i used. no i havent changed the oil since. i did change the filter though since i had to change a power steering hose and i needed to take off the filter to get to the connector.
