Minnesota_expy
My 2006 Expedtion is having the weirdest air suspension issue, it seems unwilling to attempt to inflate passenger side bags, but won't deflate the driver's side, however when you start moving it goes back to normal, both sides inflate and hold their air correctly and it self levels as it should.
But if you stay still for a good 30 minutes, it says "Check Suspension" and when turned off it won't deflate the drivers side bags.
Attached picture is it sitting after eight hours without being run, left side held air, right deflated. as far as i know, it should deflate both sides when left in park and shut off.
Never had problems with it, it's perhaps the nicest example of a gen 2 expedition i've ever seen, it's minty fresh with less then 60,000 on the clock.
