2008 no start
Joeb1
Alabama
I have a 2008. Ran fine all week. Pulled it out of the garage Saturday morning. Miles to empty said 60. Parked in driveway with a slight incline ( rear lower). Tried to start it about 20 minutes later and all it did was crank. I checked the fuel pump crash reset, the fuse and relay and all are fine. Getting some conflicting info on a fuel pump driver module. Does an 08 have one? Where is it cause I can't find it.
docraymund
philippines
Spray starting fluid first to see if its a spark or a fuel issue. There is no driver module in this model. The PCM controls the fuel pump.
Bedrck47
Elizebethtown, PA
How many fuses did you check?
How did you check them?
What was the fuse # and location?
How many miles on the Expy?
