99WhiteC5Coupe
Okay well it was in fact the water pump! I guess it just took my dealer a week to figure it out. I've been busy with going out of state for the races, the wife picked up the truck Friday. I need to go out and look at it, as I'm not sure if the pump on these are internal or externally driven. If its internal and leaks that would make since to me, about the white smoke "that dealer reported". Also if it is a internal driven water pump, should I be concerned with any internal damage to motor, from coolant leaking through?
The engine water pump is externally driven.
Amazing how it took your Ford dealer so much time to find a leaking water pump.
I had the same problem with my Ford dealer.
I’m glad you’ve found the leak and had it repaired.
