2WD Expy 4.6-Slow Acceleration
JUST4FUN
Admin
Il
What scan tool are you using ? can you see the monitors ?
JUST4FUN
Admin
Il
the o2 sensors switch lean rich lean rich and adjust the fuel trim (long term and short term) so bank 2 sensor 1 is the o2 sensor, then the cat, then sensor 2 monitors the catalyst reaction or efficiency. if this don't jive with the computer parameters then a p0430 code is set.
B
BattleRat
Chicago, Illinois
Oh I gotcha!
I use a program that installs into a computer, and connects to the car via usb to OBD 2. You get complete details and live monitors.
B
BattleRat
Chicago, Illinois
After replacing the bank 2 sensor 2 it seems the problem has been fixed a bit, but not by too much.
I was wondering... what should the reading be on the TPS(throttle position sensor) when the intake is closed? I think mine was reading over 20 when my foot was off the gas.
JUST4FUN
Admin
Il
Key on engine off tell me what happens when you go from closed to all the way open on the gas with the tps
JUST4FUN
Admin
Il
Im wondering if the TPS is bad the low reading seems high stamp might be a little more knowledge on this
tifanydire
