4th Gen Expy FORScan Modifications
Dennis48755
Caseville, MI
jgudnason -
Awesome, updated FORScan and the gauge temps worked for me also.
What does the forward distance alert feature do? I didn't find mention of it in the 2018 Expedition owners manual.
Dennis48755
Caseville, MI
Thanks jgudnason, very interesting thread. I did find the Distance Indication in my manual, helps to use good search words or better yet a page number.
What did you conclude from your attempt to turn the feature on with FORScan?
tmorris
US
I can confirm that writing to IPC on my 19 Expedition now works using version 2.3.29! Temp above gauge cluster works with the following values:
720-07-01 xxxx xE5x xxxx With Brake Control
720-07-01 xxxx x65x xxxx Without Brake Control
If anyone knows any other changes to IPC that work, please post as I cannot yet find an updated spreadsheet for the Gen 4's
tmorris
US
Following Changes to IPC all working with FORScan ver 2.3.29 on 2019 Gen 4 Expedition. All working using the available existing Ford/Expedition spreadsheets.
Temps above Gauges
Disable Triple Ding at vehicle start
Disable Door Ajar Chime when vehicle running
Disable Drivers Seat Belt Chime (Did not test passenger seat belt chime which requires a different value change)
If anyone has found a successful way to disable the Auto Start/Stop without getting the Battery Service warning on the display at startup, please post!
wakeboarder
Fort Lauderdale, FL
Has anybody tried enabling the global windows on the 2018 or 2019 XLT with Forescan? This is a standard feature on the Limited's and Platinum's.
FYI - Global windows is the ability to open or close the windows with the keyfob.
If not, can a Platinum or Limited owner let me know what theirs shows for the following lines so I can check it against the F150 spreadsheet?
BCM 726-17-01
BCM 726-17-02
BCM 726-30-01
DDM 740-05-01
PDM 741-05-01
jgudnason
Calgary, Ab, Canada
I conclude that it was successful. Toggling the bit on in the IPC enabled the option in the menu. once checked off this is the result (see picture).
jgudnason
Calgary, Ab, Canada
Temps above Gauges
one of the first things i did,
I only ever did this one:
Auto Start/Stop Disable; BCM 726-48-02 x0xx xxxx xxxx
I dont get any errors or whatnot from it, just no auto-stop.
wakeboarder
Fort Lauderdale, FL
BCM 726-17-01
BCM 726-17-02
BCM 726-30-01
DDM 740-05-01
PDM 741-05-01
I tried it today and confirmed that the values in the F150 spreadsheet work for global windows.
Global Window Open/Close
BCM 726-17-01 0101 0101 014A
BCM 726-17-02 0101 0101 014B
BCM 726-30-01 0101 xxxx xxxx
DDM 740-05-01 Dxxx xx
PDM 741-05-01 Dxxx xx
On page 101 of the manual it mentions that the moonroof may have an option to vent using the key fob. Can somebody with a Platinum or limited confirm that the vista sunroof does or does not open with the global windows?
