TactialMonkey
So far I have done the pedals and shift boot but the transmission is soon to come! There are 2 transmissions for the F:150 the M5OD which is a 4.6L transmission and should only be used for the 4.6L but if you don't believe me put one behind a 5.4L and blow it up in 30 days. The other transmission the one I will be using is a ZF5 S5-47M (the "M" is for modular engine the 5.4L and 6.8L have same bell housing) the transmission is a direct bolt up to the engine and all you need is the transmission and a new fly wheel and drive shafts for sure and depending on the transfer case (I have a 4406-10 the evil ESOF which I will be killing for a manual linkage) and transmission that were in there you may have to change the cross member I think a cross member from a donor truck will work but I'm not sure so I will give a detailed write up of how to change pedals and install a boot for now and add later!
