Hi everyone,
So, I picked up a used expedition and finally got her running good so now it's time to move on to the other things...namely the AC. I have very limited tools and also very limited funds but here's what I've done so far....
Pulled the connector loose from the low pressure switch and jumped across to see if the compressor would kick on - nothing
Pulled the connector from the high pressure switch and jumped across it - nothing
Took my little hose and added a bit of R134 with engine running and AC on max - nothing
Pulled the low pressure connector again and ran a wire from the positive battery terminal to the Black/Yellow stripe wire with everything off, including the key, again - nothing happened
I can't think of anything I may have missed to try and get the compressor clutch to engage and I didn't pull the connector loose from the compressor itself as it's a pain to get to and to see so as to make sure I'm not hitting the ground wire terminal by trying to put power there. So, this leads me to believe that the compressor clutch is bad. The compressor turns by hand so I know it's not froze up or anything.
Any other thoughts? also, if the clutch is my problem, can it be changed on the truck or do I need to pull the compressor completely off to change it?
Thanks in advance
Thanks in advance
