I have cardboard between maf and filter. Computer is reset after every sensor change. The engine lopes worse with maf unplugged. Idles smooth maf plugged in and half covered.
I would suspect major vacuum leak or weak fuel pump.
Reset the pcm & ..
Check your fuel pressure at the rail. Since it barely runs the reading should be obviously low if fuel pressure is the problem. Look for a minimum of 30psi @ idle.
Check and see how much vacuum you are pulling at idle. I would look for 16-20 inches at idle. This may not work well if it barely runs as it will be skewed low.
Go from here and let us know your results...
Reset the pcm & ..
Im leaning toward fuel pump. I believe i would hear a leak that bad.
