Amealey84
Driving down the road my truck died. Didn't sputter at all just died. It will crank over but not start, fuel pump primes but I get no fuel pressure at the rail, just a tiny "psssh" for a half a second but no fuel comes out at all. I checked all the fuses and relays and none were blown or melted. I did notice the connector plug was melted for the passenger-side (black wire sheath) second O2 sensor. Cut it out and hard wired in. Will this be ok?
It will start with starting fluid but dies after. So it is getting spark. This is driving me crazy!! Please help.... the part making this so difficult is having no multi meter to test loads. Could it be not enough power to fuel pump? Noticed the harness that runs underneath had gotten close to catalytic converter and melted the plastic sheeting a little but all wires in tact.
When ignition is on, I went under and noticed a high pitch "humming/ringing" noise coming from seems like the flywheel area? Which is close to the harness I mentioned but I'm 70% it's coming from the flywheel/tranny area'ish.
Things I've done
1.checked fuses/relays
2.checked fuel reset button
3.Confirmed fuel pump primes
4.Confirmed spark with s/fluid
5.Changed fuel filter
6.Check for vacuum leak. Nothing I could find.
I've done everything I can think off besides changing the fuel pump.
Things I've done
