a few issues with my Expy
mrpersuasive313
OK I have a few issues with my 1998 5.4 v8 Triton,
1. It's misfiring
2. It shudders only when I accelerate, never in idle
3. My heat blows terrific in the sections but off and on faintly in front section
4. I have a ABS light on with a left lean bank . I think it was PO10171
5. My 6 disc CDs changer is malfunctioning, when the car is off, you can hear it trying to work but no ejection or movement.
It's has just over 167,500 miles
If any of these I can fix on my own please let me know, any and all advice is gravely appreciated seeing this is my # 1 family vehicle, I hope I posted in the right section.
BigJuicy02
Hinesville, GA
Misfiring, Shuddering and left bank lean will most likely all be one issue. If you have a coil going out it can run fine at idle but as soon as you put a load on it (accelerating) it starts failing. You should have a check engine light on, ABS light will not come on for misfire codes. Have it scanned and it should tell you which cylinder is misfiring.
Once you know which cylinder it is, replace the coil and plug. 9 times out of 10, that solves it.
ABS light is a different animal, could just be a bad sensor but you need to get it scanned to get the actual ABS code.
CD Changer I can't really offer any advice. As far as I know, you cannot repair those. Someone else on the forum might know of a way. I would either replace it or upgrade the sound system, which can be a pain with the Mach Audio. I know because I have the same one.
Hope you can solve this issues quickly and cheaply. Keep us updated.
BANGEREXPO76
PLUGZONE 76
I agree. Change your spark plugs and coils. I recommend doing them all at once get it over and done with especially if you havent done them in a while or at all since owning it. ABS light could be the sensor. It could also be your wheel hub bearing assembly which is what the sensor reads that is going bad. Good luck finding the issue.
Banger
M
mrpersuasive313
I am taking it in, in the morning, to have it checked and dealt with, I will change the coils myself as well as my sensor (rear)
Another issue I forgot to mention is my exhaust sounds rough
1koerner
mesquite tx
define exhaust sounds rough as for the rest i agree with everyone else on changing the coils fuel filter ect and trash the changer if you need the parts to swap in a aftermarket headunit hmu i have everything u will need (no charge) good luck and keep us posted
MUSKYMAN52
Illinois
Is it like a running cold rough exhaust? cuz when its 6 degrees mine roars till it warms up cuz of the high revs but still kind of rough
BANGEREXPO76
PLUGZONE 76
For your exhaust issue.
Check your exhaust manifold gaskets as well as the header bolts to see if they are loose.
M
mrpersuasive313
The exhaust is almost like it's shaking when I accelerate, it's a loud rattle sound n there white pure white smoke coming from it!
Goff69
