LastExpo2000
shouldn't be a problem... just make sure they are good spacers and you are going to need to re-torque them every so often... like check the torque with every oil change... also I would look for "hub-centric" spacers too if your gonna use 1" or bigger
Would it be a good idea to use some lock tight on the studs before I torque them? I should be able to fit 305s right? I just want to make sure and would that be a tight fit? I'm keeping stock size rims
