Motorcraft SP-515 are the plugs. Figuring out if you have a coil going bad without a CEL can be a pain. Might have to have someone/dealer do a power balance data logging through the OBDII port. Only reason I know, had same issue. Know the stutter of which you speak. My power balance revealed 2 coils going bad and I never had the check engine light show up. Drive me nuts for some time until we figured it out. Two fresh coils, no more stutter.
FYI...if you do the plugs, make sure you invest in the lisle tool for broken spark plugs. Your 07 has the ******** 3 piece spark plug design that likes to break off. With out the removal tool, bottom half of the plug gets stuck in the head. Do a quick search on 'broken spark plug' and you can read about success and failure.
