Just jacked it up passenger side rear has WAY too much play for comfort. My questsion is at this point should I replace both rears? Holy cow the axle nut is RUSTY.
You could I did not I am waiting until it goes
If you dont have an acetylene torch take it to someone who does because you will never get it apart without one. An air hammer helps too
the axle nut is the easy part
I also bought a Timken hub with the abs sensor already on it if you need it its another $80 might as well get the whole ball of wax
It was the "frequently reported fix" for the code which was to replace the wheel bearing.
Skip to 4:10 these same lights I had too, he uses a blue driver that actually tells him it's the wheel bearing. Same situation.
Oof. Thats misleading. Its not telling you that the bearing is bad. Its telling you the ABS sensor is bad, and the fix is to replace the hub assembly. Thats because its a sealed unit and it contains both the bearing and the sensor.
Instead of continuing to throw money at this thing you should go buy that new GM you been talking about
