5280tunage
You do, but it takes an extra 10 minutes or so, not a big deal.
Refer to post 31 in this thread for the Raptor transmission skid plate, and post 51 for the oil drain access cover that attaches to the Raptor transmission skid plate.
Thanks @scottdm (tascaparts is coming up a bit more expensive on the "undercover").
For anyone else that wants to SEARCH for pricing here are the P/N in a cut / paste form!
Under Cover - Product ID: HL3Z-7222-A
Plate Bolt -Product ID: -W505594-S440
Sunroof Frame Screw - Product ID: W717268S439
Front Shield U-Nut - Product ID: -W717634-S439
Under Cover Access Panel - Product ID: HL3Z-7222-B
Tasca Parts is coming up a bit more expensive on the tray - shipping is gonna put it over the top - ill be shopping around to see if I can avoid the shipping!
Slipstream: how did you get the back part of the front skid plate bolted onto the frame? I did the same thing buying the 09-14' full package and can't figure out how to bolt the back part of the skid plate. Did you drill/tap the rear holes on each back end into the frame or did you use the included bolt hangers to put them on? Thanks!So in the spirit of broadening our collective knowledge.....the RCI engine skid plate ended up to be quite the project. I ended up ordering the 09-14 F-150 plate as suggested in prior posts. For reference I have a 2019 Limited Special Edition. If you are counting on them being a 'bolt-on' application...don't. I ended up getting them installed and they fit nicely now, but it cost me $150 bucks of shop time to make the required modifications. The front brackets needed to be modified (drilled an hole in a different spot) and added 2 more bolts to better secure the 2 plates together. Also contrary to the post above (which I think is using the 15-19 F150 skid plates), the mounting location of the brackets is different. I ended up mounting mine on the front 2 bolts (including the tow hook bolt) instead of the back 2. This was the only way to align the rear bolts on the 2 plate. Pics attached. View attachment 38214 View attachment 38215 View attachment 38216 View attachment 38217
