When I bought the interior from the 05 King Ranch to transplant into my truck, I was assured by the recycling yard that they were heated. Unfortunately, upon arrival, I found that they were not heated. While I was cleaning and conditioning, I decided to install Rostra aftermarket seat heaters. Due to the left bolster of the drivers seat showing a bit of compression, I swapped the seat bottoms between the two during the install.
I realize now that I did not take enough pictures of the wiring or switches, but the Rostra kit I bought (#250-1802) only required to run power and ground. Due to my truck being an Eddie Bauer, I could not install the switches in the factory location, as the openings were too large (I needed a 20mm hole for the new switches). Luckily, the interior I bought came with a clean center console. So that I could install a wood dash kit if I choose, I installed the switches in the same spot as the factory ones would have been, as dash kits usually have cutouts around the Eddie Bauer heat/cool seat switches.
I found 12v+ (key on) power from one of the wires on each power seat. That circuit is fused, and I also kept the fuseholder in place that came with each kit.
Note that these seat pads were trimmable lengthwise. The only other modification needed was to cut a divot out of the seat foam to accomodate the bulge from the thermostat.
The caveat here is that I don't believe it would be as easy (or possible?) to install these into an Eddie Bauer with heated/cooled seats, due to the perforated leather, and air ducts in the seat. However, any XLT or FX4 leather or cloth *should* accept them?
Here are some pictures. I'll be happy to answer anything I can. Sorry again for the small amount of detail pics.
Switch Location
Switch Location
