MHammertime
Need audio gurus help!
So I'm installing a Kenwood HU on my 03. Using a Metra harness, I follow the instructions per Metra & Kenwood manual. Before uninstalling the oem radio, oem radio (6 disc changer, no nav) worked fine. Now, for some reason, i'm not getting any power to the red wires. I'm getting power to the yellow constant 12v wire. Verified this by touching red harness wires to the yellow. Checked the radio fuse in the kick panel and it was okay. Haven't checked the other fuses. Ran the car for 30 minutes thinking alternator went dead and no luck. Also not getting any voltage readings on the red wire at the original radio harness pin.
Any suggestions?
thanks in advance
Any suggestions?
thanks in advance
