rtbrjason
I’m noticing a noise similar in sound to a bad wheel bearing in a4wd. Mostly noticeable at lower speeds under some load. I have a switch rigged to kill fuse 104 (awd) under the hood. When I turn the switch off, the noise goes away completely, so I’m certain it’s not a wheel bearing. It does sound like it’s coming from the front. Hoping it’s not a bad front differential. A4wd as well as 4x4 still seem to be working fine. Any ideas?
