Biggest tires that fit on stock 2022 Timberline
LazSlate
Arizona
These trucks really do look good with just a slight increase in tire size! Heck they look good stock too. Follow up question for those that have been kind enough to answer me - can you fit a spare of the same size under the truck?
Depends on the use for the spare. If you are overlanding far away and plan to use the spare as a replacement for many many miles, or just to get to a place to fix it?
I carry plugs and a compressor. In the past on other vehicles when I got a flat I would see it deflating, find the nail or screw and fix it in minutes without even removing the tire. Massive blow outs of course would require to use the spare and I only plan to drive to a place to get a new tire. The difference in height is not a big deal for the diff or computer. But I do plant to pull my spare and check the clearances for curiosity and I will post the results.
doubleeagle45
Georgia
Taking the Readylift (buy 2 kits to get the 1.5 pucks) would work.
Can someone explain this, or direct me to where I can find more detailed information about it? Looking for part numbers so I can cost it out and start saving up. I think if the Timberline is already about an inch over stock, then about another 1.5" would be "just right" .... Now all I need is the money for the mild lift and the larger tires to fill that space up. (Mentally spending money I don't have, on modifying a truck I haven't seen yet, which hasn't even been scheduled for shipping, let alone made it to the dealer yet.... ha!)
ak49
Alaska
Here you go...
ak49
Alaska
The topic of larger spare tires has been posted a few time on this forum. It seems as though a 295/70r18 may be the biggest tire possible without too much modification. Unclip a wiring harness and maybe deflate a bit. That said, there seems to be some debate over whether a matching spare is all that necessary. Plugs and a compressor, or limited use of an undersized spare on the front end for a short run. :shrug:
rgbpixels
MA
I put 295/70/18 BFG KO2’s on mine this week. Everything stock, no rubbing.
Hi badfish. Do you have any photos or updates? I went to two car places and they said 275/70/18 were the largest but took no measurements
badfish
HTown
greenmachine23
Kansas City
Hi badfish—any updates after a few months of running on the bigger tires? I have a ‘23 Timberline same color as yours. Want to upgrade tires but hate rubbing. You are not running spacers, correct?
LazSlate
Arizona
Its all about rim offset. I run 305/70/17 very wide tires with zero poke and zero rub.
