JLucas
Having an odd issue with the front and rear blower fan. I replaced the blower motor resistor on the front a few months ago when fan would only work on low and high settings and it fixed the problem. A few days ago front fan would only work on high setting. Yesterday fan stopped working on the high setting as well and I also noticed smoke (electrical smell) coming from the front vents. I tried replacing the resistor again but that did not work. I checked the fuses and relays without luck. Now the rear fan is stuck on high (even when its in the off position on back panel) if I try to turn the front fan on. I'm guessing I have an electrical short somewhere....Anyone have any idea what the problem is?
Thanks for your help.
Joe
Joe
